a week ago i woke up to find my boiler not working. It turned out that there was not enough pressure in the system so i used the filling loop to top it up to 1.5 bars.
A week later and the same thing happened this morning. So i filled it up again and i'm obviously concerned now that there is a leak in the system somewhere (especially as i've boxed everything in and laminate floored over the entire house more or less!!)
Anyway, when i got back from shopping this evening, it had again dropped to just under 1 bar.
Having searched for advice on the internet, i decided to look for leaks around the boiler.
I've found 2!
1) coming from the bottom attachment for the filling loop
2) From the pipe coming out the far right hand side of the boiler at the bottom with a red nut/tap on it.
I've re-attached the filling loop just as a cap really to collect the water coming out there.
But can someone tell me what the other leak is due to?
Any idea how much this will cost to repair?
I've found 2!
