Hi all,
I`m running the wires for a new ring circuit in my utility room.
The walls are then going to be studded, insulated and boarded with 50mm batons
Do i need to put the wires into a conduit or can i just clip them to the wall and have the insulation and boards over it?
Appreciate that if it needs to be rewired in the future then conduit will be the brighter option but there are so many corners it won`t make a difference and i`d just re run it.
If i do need to use conduit then what should i be using for regs.
I`ll be using a competent sparks to connect to the board and to sign it all off afterwards.
Thanks for any replies.
