Conecting backboiler to combi boiler
5 Dec 2010
Cumbria
I'm thinking of fitting a boiler into our stove and connecting it into heating sytem, I was thinking i'd need to fit motorised valves to bypass the combi boiler when it's turned of, and fit another pump to the system that's turned on when the stove is turned on, to circulate the water and bypass the boiler, or could i just plump it in, turn the boiler temp down-and let the boiler pump it round the system?
Any thoughts would be much appriciated. thanks
get someone in who knows what he's doing, the design of connecting two systems together is not a DIY job.
Question? aren't most combi's designed to work on a sealed system and if so you cannot connect an uncontrollable heat source (stove) to a sealed system.
Please correct me if wrong.
