I hope it's not, as it's fitted in the airing cupboard in photo. Unless there's more than one model of Horst. C11, it's defo a single channel programmer.
I have seen this set up before, the single channel timer connects to both cylinder and room stat, I reckon the zone valve is only to stop unwanted circulation when the gravity hot water is running so I would go for a faulty cylinder stat.
I hope it's not me making it even more confusing 😄
Surely fitting a double channel controller won't work as only have 2way valve upon inspection?
Today I phoned estate agent and have asked him to call previous owners to ask how they used to heat hw in summer.
No point asking if there was something wrong with hw when sold house ( temp rectified by valve switched to manual) as they'd never own up!
Thanks for help!
It would work if it was gravity circulation on the HW circuit. It's know as a 'C Plan' system
No point asking if there was something wrong with hw when sold house (temp rectified by valve switched to manual) as they'd never own up!
Thanks for help!
I know it's an additional expense (say £60-120) when purchasing a house, but it's always advisable to get a report on the heating/HW system from an independent heating engineer. You then don't have any nasty surprises.
