I'm in the process of planning a new bathroom and looking at all the various (cheap and costly) options and getting very confused about pressures and flow-rates etc
Current setup: gravity fed vented system in 1939 house with one bathroom. As far as I can tell a 15mm rising main feeding all cold taps (1 in kitchen, 2 in bathroom). Cold cistern is sat directly on joists about 1.5m above bathroom basin taps and 2m above bath taps. 22m feeds hot water to bathroom taps.
My rough and ready flow rate calcs show 12l/min from cold taps (measured one at a time) and 40l/min from bath hot tap. Kitchen tap is a ceramic disc mixer. Bath tap is a spindle mixer.
I want to get some snazzy, designer ceramic disc taps for the bathroom, but there are disclaimers in the brochures: "although work with low pressure, recommended for use with minimum 0.5bar". Now, by my calcs, I have 0.2bar to the bath tap, which would not be good enough (?). But, there seems to be bucket loads of water coming out. What's going on?
In addition, I thought my onlu option for a good shower was to install a pump. But if I raise the cistern to about 2m head (to shower) and install custom 22mm feed pipes, I should get the same bucket load of water coming out as the bathroom tap. Or am I barking mad?
