Hi all, I'm no expert in central heating so could do with a little advice, I have recently removed a radiator and drained the system and refilled with water without inhibitor for now, I will add later as I will have to drain the system again.
I can bleed the system successfully and the pressure is at about 2.5 bar, but As soon as I run the heating system I am getting water venting by what I guess is a relief valve, it's venting to a pipe that goes outside the house,, the relief alve the other side of the wall seems to be spring loaded with no adjustment, so is it doing its job, is it faulty,? Why is it venting the system, in the morning the system is only at .5 bar if that
