- Joined
- 4 Oct 2018
- Messages
- 5
- Reaction score
- 0
- Country
I live in a 1940s semi, the only source of heating I have in the house is a hot water cylinder with an immersion heating the water, no pumps for the hot, just gravity feed (no gas, boiler or central heating just hot water for the taps)
I am attempting to remove an old condemned stove with a back boiler but when I drained the pipes going into the back of the stove the water wouldn't stop draining, and when I checked the hot water cylinder I could see it was refilling.
Coming off the hot water cylinder is the normal cold in, hot out, overflow.
as well as a couple of 28mm feed and return pipes going through what I assume was just a normal calorifier which goes directly to the back boiler (there is a also radiator teed off the 28mm pipes in the upstairs bedroom, no idea if it has ever worked as I have never lit a fire in the house)
My assumption is that I could just cap off the 28mm pipe going through the hot water cylinder, then the water would drain from the back boiler and job done, not entirely confident with damage I could do I called a plumber to do it for me which is when things started to get interesting.
The plumber was adamant that there is a expansion/filler tank somewhere hidden in the house as far as he was concerned this is the only way that the pipes around the back boiler could possibly be filling up,
however I have been pretty solidly updating this house over the last year and I am sure that there isn't, I have been in the loft and had most of the floorboards up and I am sure that there isn't a filler tank unless the previous owner was a bit special and did something mad like hide it behind a false wall or up the chimney.
so current theories are:
Plumber = hidden filler tank (honestly the only place I can possibly think this would be is either inside a chimney or under a floorboard but I haven't heard any filling noises so I am sure it can't be this)
My theory 1 = The calorifer has split inside the hot water cylinder which is how water is getting into the pipes around the back boiler, the water tank is less than a decade old but the fireplace is one of those Parkray 1970s things, I am thinking the previous owner maybe lit fire and there was some air in the system which ruptured the pipe. (if this is the case I am amazed I haven't had some horrible illness though)
My theory 2 = (long shot) the pipes from our hot water tank go next door which is where the filler tank is (we live in an ex council house semi so who knows what bodge jobs have been done over the years), although I doubt this as the houses are clearly two separate properties from the beginning so i can't see the benefit of one filler tank for two houses.
if this isn't clear then I will try and draw a diagram, I just wanted to know if anyone has come across this setup before or has any other ideas?
