My old galvanized tank is about 3 feet above the hot water cylinder which it supplies by a 28mm pipe. The hot from the cylinder is taken from the cylinder on a 22mm pipe. I am replacing the tank with a plastic one in the loft (about 6 feet above the cylinder), can I use 22mm feed?
The fittings and pipe work are considerably cheaper in 22mm than 28mm, and if the outlet is 22mm what's the point of feeding the cylinder with a 28mm pipe?
Mike
Mike
