Hi
I've been looking to replace a dimmer switch that causes lights to flicker (even when on full) — all the replacement switches I've looked at seem to have L1 L2 and one other connector.
The switch has two sets of wiring coming into the box — earth & then two black wires and two red wires. One of the red wires was not connected to anything and is taped up.
If I wire the two blacks into L2 and the red into L1 as suggested by an electrician mate the dimmer switch has no effect at all (although the second switch controls the light on/off)
If i copy (as close as possible there were no markings I could see on the old switch) the layout on the old switch the dimmer works but buzzes and flickers. I've currently got it all switched off (not a huge problem) - but I'd like to sort it.
Have attached a diagram
