Our detached garage that is being converted is at the stage of having its floor built.
We understand that from our research it's a DPM, foil faced insulation (we can only do 25mm due to height), tongue and groove OSB, underlay and then laminate floor. My research shows that the OSB will move with the seasons, and I don't know what impact this will have on the laminate stability.
We have found other polystyrene boards in DIY stores that are 5mm purporting to be suitable to ultra cold concrete floors, and no additional OSB or underlay needed, so laminate would to directly ontop. I have attached the image of the product
I'm confused how such boards that are 5mm would out perform 25mm of insulation in the traditional way.
What's the best approach for stability and heat retention.
Note, our garage is detached and is small, around 12m2 and doesn't need building regs.
