I am trying to replace an old bathroom fan with a new Airflow iCON30. The old fan was powered through a spur from lighting circuit. Only live and neutral wires were connected, the earth wire was not (the lighting cable has unsheathed wire in the middle and this wire was cut). The new fan requires a 3A fuse and also I have been told that 30mA RCD should be installed.
So I was thinking to install RCD protected fused connection unit (http://www.alertelectrical.com/prod/336/rcd-spur-connection-unit) between the fan and the spur from lighting circuit. My problem is that RCD requires 3 wires to be connected : live, neutral and earth. My fan is double insulated and has a module switch installed inside, so that it operates only using live and neutral wires.
My question is how to wire my fan that requires 2 wires (live and neutral) to RCD that requires 3 wires (live, neutral, earth) to spur from lighting circuit (which i presume is connected to earth)??
Please help!!!
Please help!!!
