AMprof, with respect to the replies you had, you didnt give much information.
If you had said something like:
"I need to connect two 6mm cables, one to feed a hob and one to feed an oven, onto the existing 6mm feed from the cooker switch.
Whats is the best way to connect the cables?!
Then people would know what you are trying to do.
You may have wanted to join three pieces of 6mm armoured cable in a garden, or join the cable in a wall, or in a loft.
