connecting a cm927 to a vaillant combi boiler
17 Apr 2010
Liverpool
HI ALL my names phil electrician from liverpool. i have been trying to get this cm927 wireless controller to work on this brand new vaillant combi boiler. checked all wireing link took out from 3 4 and sender put in there place. pn from fused spur to sender 4c and earth used to boiler pn to boiler other 2c for terminals 3 4 there is a neutral terminal 5 but looks like its just for thermastat. when unit downstairs is in the off pos boiler still running any ideas would be great owner said it worked fine with his old boiler
The wireless receiver will definitely need a neutral connection, although I can't make head or tail of your post so may have completely misunderstood what you've done so far.
Phil: it's been a few months since I've looked at an Ecotec boiler, but it seems to me that you're trying to connect a wireless device to the mains terminals 3,4,5 - when you should be using the e-bus terminals.
There's only a need to remove the link 3-4 when you're using a mains room 'stat. Wireless devices are connected via the e-bus terminals.
I'll tell you what I would do if I were me: I'd get shot of the wireless 'stat and fit a standard, dependable room 'stat.........
Lucia.
thanks p.o.d the e-bus terminals to my knowledge cant be used in the uk on vaillant boilers. thanks againl
Lucia.
I agree with this advice.
I connected a Vaillant VRT360 programmable room thermostat (230v) to my Vaillant combi boiler and haven't had any problems to date.
