What type of cable to connect from the double insulated recessed light to the cable connectors?
Right, so I've removed our pendant and due to the new fixtures light distribution, I also need to add some recessed lights (fire proofed if that makes a difference). The recessed lights have a chocbox in a plastic casing (L/N) which I need to connect to the cable connectors (I used wago).
I would like to use my existing two core and earth cable (6242Y), but not really sure if this is the right cable for the job and if so what's the best way to remove the earth wire: do I yank it out, do I use some nut, do I just cut the exposed earth or do I buy a two core only cable?
Cheers,
A
Cheers,
A
