I am replacing an old cooker extractor hood that was previously installed by a kitchen fitter. It packed up so I've got a new one.
The extractor is on the lighting circuit. After removing the old one, I found it was wired to an FCU (no switch) within the chimney cover of the hood.
The new extractor has a plug (I suspect from its flex that the old one did too and it got chopped off to wire to the FCU).
I see 2 options but not sure which is best:
1) Chop the plug off the new hood and connect to the FCU as the last one was.
2) Replace the FCU with a single socket behind the hood cover.
The first option involves chopping a molded socket off and the second option involves putting a socket on to a lighting circuit, albeit inaccessible.
Ideally it would be wired up to the kitchen socket circuit and have its own accessible switched FCU too but I'd rather avoid ripping up the whole kitchen for a cheap hood provided it is safe and not breaking regs (albeit not ideal).
Thanks in advance.
Thanks in advance.
