advice please.
I want to put up an outside pir light.
I have power in my shed in my car port. I have a proteus cu in the shed which is fed from the cu in the house. the cu in the shed supplies 2 outside garden sockets, and 2 double sockets in the shed. Can I take a switched fcu off one of the shed double sockets using 2.5mm wire and use the fcu to connect the outside light to (do I use 1.5mm t&e for this?).
Could I also connect a low voltage bulk head light from the other double socket in the shed via the same method above?
