connecting spots
22 Jan 2007
Oxford
whats the crack with these then? i understand that joint boxes are a no-no now, is this correct?
I think he means when connecting downlighters what is the correct method for joining the wires?
yes you can use junction boxes as long as they are small enough to pull through the hole for the light so they can be inspected..
or you can get "choc box" terminal boxes which are just 3 terminal blocks in a plastic clip over box..
not sure if i like the look of these..
