Connectors for tamper loop
18 Feb 2006
Birmingham
Hi all
Will be fitting an alarm at home (Texecom Premier Elite 24 Metal) and wanted to know what was best to use for the daisy chain of the tamper loop. Is there anything better/neater then a strip of connector blocks?
Hi all
have you wired the system yet? the modern way is not to have a daisy chain of tamper loops, zones can be wired EOL now, read the supplied instructions for more details
Hi all
At present 6-core has just been run to each room where PIR/Door contact is needed, along with 2 for SAB
Hi all
in that case connect EOL, no need for a global tamper loop
Hi all
How does EOL work?
I've fitted a veritas r8 before, and has been a while
Hi all
How does EOL work?
page 31 of the installation manual supplied with the panel, also its explained in the 'Alarm Sticky' at the top of this group.
Hi all
How does EOL work?
Thanks, I'll get some resistors on order.
Is using EOL better?
Hi all
How does EOL work?
resistors come supplied with a new panel or a resistance is selectable via jumpers directly in the PIR's (dependant on PIR's bought)
Advantage of EOL, uses less cores (2 to a contact, only 4 for a PIR), easier to fault find in the event of a fault on the tamper loop, and a tamper loop fault wont stop you setting the system, which with a global tamper fault would be a problem, also neater in the panel.
Hi all
How does EOL work?
Appreciated
Will most likely be the Texecom Premier Elite, but open to suggestions
