Conservatory door water issue
12 Jan 2023
Hi all,
Desperately trying to resolve an issue. Conservatory door's are somehow collecting water under the door's causing water damage to the wood and it has caused it to rot. I fitted the runaway section last week but after raining today, it has made zero differnce.
As the outside picture show's. There is a wet area from the guttering which has a slow drip but i cannot see how it would hit the door frame?
Any idea's would be greatly appreciated
External level far too high , probably breaching the dpc and rain will splash up the door .
Do you mean the external frame above the brick? We only moved in last July. Fairly older property do you think it’s been an ongoing issue ?
What would be the best way to resolve this ?
Ouch, not a cheap one then! But i have no other option other than continue to cause more damage. Thank you for the help Fox ill look into doing this
