Z
zaarin_2003
Hi all,
I wonder if you might know the answer to a question I have.
We are having a replacement conservatory built and wish to move the kitchen from its current position to inside it. The sink will be located on the far side of the conservatory and the waste pipe would run from that to the gully, which is where the existing kitchen is, the other side of a wall on the opposite side of the conservatory.
This means laying a drainage pipe horizontally, at an angle with a drop, through the floor.
The conservatory company have stated that our plumber will not be able to run the waste pipe through the selotex insulation layer of the new floor, because it will be running almost horizontally, at an angle enough to ensure a decent drop for the water to flow, but not steep enough to prevent it cutting a long trough through the insulation, which is what they don’t like. They state that recent changes to building regulations prevent us doing this.
This complicates things for us, because it means the pipe will need to be above or below the selotex, at a more slight angle, and probably require a pump to pump the water along, rather than relying on gravity.
I presume the new regulations being referred to are the ones detailed in Approved Document L: Approved Document L, Conservation of fuel and power, Volume 1: Dwellings (publishing.service.gov.uk) which came into force June 2022. Is this correct? And, if so, I presume the concerns are related to the requirement for continuity of insulation. These requirements specify that insulation must be free from gaps and such and that any services breaking the insulation layer must have insulation tight around it, and presumably not a long channel cutting through it.
My question is, do these new regulations even apply to extensions/conservatories? From what I can see, paragraph 4.17 of Approved Document L, which details the continuity of insulation requirements, only applies to new dwellings. There is also a provision at 4.17(h) which allows for services to run through it anyway. Under 10.12-10.13 (adding a conservatory or porch to an existing dwelling), it mentions that fabric elements such as insulation need to meet the U-value requirements of section 4.7-4.8 and table 4.2, but there is no mention of ‘continuity of insulation’ such as there is for new dwellings.
Z
Z
