Conservatory guttering has no drain or soak-away
25 Jan 2010
Our conservatory guttering is connected via a downpipe to a water butt. Currently, if this overflows it simply spills out onto the concrete outside our conservatory and kitchen.
There is no drain outside this part of the house. All the downpipes on our main roof guttering go into our neighbours property (we live in a semi). I can't see any way to link our conservatory guttering into the main roof guttering - the most obvious route would cut across our kitchen door to reach the neighbours downpipe.
A soak-away would seem to be other option, if we didn't have heavy clay-based soil.
Not really sure what to do! Leaving things as they are doesn't seem a great idea as I'm sure this water is causing problems somewhere, even if I don't know it yet.
Yet another nice "surprise" I've realised we've inherited from the previous owner(s)...
If the conservatory wasn't there you'd still get the same amount of water.
But surely the same is true for main roof guttering, yet we feel the need to drain that correctly? Do I really not have to worry about this smaller volume of water?
Yes, but it would be spread over something like 10m2 and not concentrated in one spot to soften the ground at that point
Just run a underground drainage square hopper into a 90 degree angle with a few mtrs of pipe in the ground. Bit o' digging, £30 in materials, job done. :mrgreen:
