Conservatory roof supplier and installer in Cardiff?
17 Nov 2005
Cardiff
I am fairly new on this site. Not sure this is the correct section for this discussion?
I am looking for anybody locally (Cardiff, UK) who knows of a supplier of Triple Shield Glass (with Argon Gas) and Pilkington 24mm Activ™ Blue Solar Control Glass Roof which gives a 'U' value of 1.1.
I have a 9m square Anglian installed conservatory which is currently fitted with a 24mm Poycarbonate roof. Which has a 'U' value of 1.6 to 1.75.
I have found a company in Coventry who will supply the above (with frame) but I would have to find an installer.
Any readers can please help? Thanks. :roll:
Hi there,
I would suggest contacting a company called Ultraframe via the web, They manufacture conservatory roofing systems. They have an approved installer scheme, they may be able to point you in the direction of one local to you.
Triple shield is the trade name for units supplied by Affordable Windows in/nr Blackpool, K2 roof systems has brought out a unit making company that do a similar unit.
You have a K2 manufacturer down your way called Crest who would supply and probably help you find a fitter. Do a search for K2 roof systems and then look for your local fabricator.
Anglian by the way use Ultraframe roofs and you should be able to replace just the glass, just a thought.
