Hi all, I'm thinking of creating a false ceiling in our conservatory because my partner will be using it for her dog grooming business. It doesn't need to look pretty, just do a job. I plan on putting 4x2's across the 3m span.
I will then clad the ceiling with some upvc - either hollow t&g or plain panels.
However I'm a bit stuck on the insulation. I'm thinking of either going for multifoil insulation or PIR boards. Will put a vapour barrier on the room side as well before the cladding.
A concern I have is that the roof void will be become dangerously hot in the summer. Will the foil backed PIR or multifoil help reflect the heat away?
I know this isn't standard, and I'm not expecting miraculous results.
I've posted quite a few times in the past about and had no replies so would really appreciate some help!
Read more: https://www.diynot.com/diy/threads/...-in-conservatory-advice.538154/#ixzz6qiw5Piki
