conservatory wiring
30 Nov 2009
Hampshire
What is the best way to get 2 sockets and a wall light into my conservatory from house.
Carry them into the conservatory and then get an electrician to design how to connect them and then ask him to do work .
More information is needed
depending on where the nearest supplies are it may be simple, it may be hard!
we need more info from you
what room is next to cons'y
how high is cons'y
just as an example. the last one we did was 2 sockets each side each fed from the lounge ring and the light was fed from the downstairs light circuit by taking up the upstairs floor and carefully drilling through to the top of Cons'y.
Conservcatory backs onto kitchen and dining room. I have A dbl socket next to the door leading to conservatory and 1 in the kitchen on the outside wall. I would be looking to put one socket either side of conservatory and 1 wall light on outside wall of house.
I have read about extending the ring main? And then using a fused spur for my lighting off one of the sockets in conservatory. Is this possible and safe to do?
Yes. In a word.
As you have aready mentioned, make sure you fuse down for the light with a 3A fuse.
