We've recently moved in to a new build apartment which I understand has communal heating for the entire building, controlled by a Digistat +2 thermostat installed near the front door.
Before we go ahead with the purchase I've been researching the necessary changes which will be required to install a Nest 2nd gen. The Digistat, as far as I can see, is powered by 240V and the Nest only takes 12V, so a direct swap over in removing the Digistat and replacing with the Nest control isn't possible.
Does anyone know if the installation will therefore require the Heat Link to be installed somewhere else (electrical cupboard, I guess) and we'll have to remove the Digistat and fill in the hole in the wall/clean up the cables where it resided? Looking at the instructions, the Nest thermostat could then be placed anywhere in the apartment - powered by its own 12V power supply (presumably communicating with the Heat Link over WiFi?)
We're looking for as seamless a replacement as possible that won't require too much filling of voids/repainting, but it seems like that might be the case here?
