- Joined
- 25 Jul 2017
- Messages
- 9
- Reaction score
- 0
- Country
Hoping someone can help me out or give me some advice with an issue I have had for a little while with my central heating and seems to be getting worse.
I have a standard gravity fed CH system in a two story house with F&E tank in the loft, boiler in the garage downstairs with a magnatec filter and circulating pump and two valves in an S plan layout in the airing cupboard on the first floor. Circulating pump is a british gas multihead and the F&E pipes join the pipework just before the pump.
My issue is that I am constantly getting air locks in the CH system which seem to be at the pump and the only way to clear is to bleed the pump via the screw in the middle which lets out air for approx 5 seconds followed by a surging noise in the pump and the water starts flowing. Once the water is flowing it is very noisy and sounds like its gurgling through the pipework in the airing cupboard. The system might run fine for an hour or so before it airlocks again and needs bleeding to let water flow around the system. When the airlock has cleared all the radiators heat up fine and the CH seems to work well. The pump itself is also very noisy when running.
Does anyone has any experience of anything similar or could suggest anything to check? Is there an easy way to check if the feed pipe could be blocked? Only thing I have noticed is that the circulating pump is at the highest point in the system other than the F&E pipes.
Any help would be much appreciated as its starting to drive me mad!
Many thanks.
Many thanks.
