I have a oil boiler with a sterling burner fitted.
It locks out each time its asked to fire, what it does is the motor runs the electrodes spark and it fires up for a short time 10/15 secs then lock out, thats as far as it goes.
this is what i have tested/tried so far in an elimanation process, removed photocell cleaned, tested photocell lead to control box with multi meter for any breaks all o.k., reinstalled.
removed lead to pump solenoid checked for voltage, 250V a/c found, checked lead to control box with multi meter for any break lead all o.k.
removed solenoid pluged into lead to see if it energised by placeing scredriver into coil it grabbed the steel shaft until it locked out then released, hope that test it enough.
removed control box no sign of burnt contacts or any damage, as this box seems to work the system can there be any electronic fault in the control box ?
Thats all i have tested so far.
am going to order photocell as cant prove its working is there a test i can do ?
seems that many parts work as it will fire up is there any thing more i can test/check?
