I intend on changing the consumer unit for my elecsa assessment and want to check the following.
Currently there is a 60amp cut-out, 16mm meter tails and 10mm earth bonding, current consumer unit is 8 way rewireable wylex unit. Will i require to upgrade the meter tails to 25mm and earth to 16mm even thou the cut out is 60amp and will not change to 100amp as there is no additional demand. will leaving the existing meter tails in be acceptable for elecsa assessment. a friend of my always replaces meter tails on all consumer unit changes to 25mm but dont see why its needed if load hasnt changed.
thanks in advance to all feedback
