Hoping that somebody will be able to offer me a solution to a small problem.
We have an extension attached to our house, and the electrics/decorating in it had been DIY'ed by the previous owner. We have owned the property for six months and moved in a month ago. Most of the property was rewired with a new consumer unit, but the budget did not extend to the extension and as I mentioned the wiring was a mess, so the electricians disconnected it, and I have since torn it all out.
The electricians left us with a disconnected Twin & Earth buried in conduit behind the kitchen walls (10mm I think) going to the extension & advised that a consumer unit would be required in the extension, when we were ready.
So my question is what consumer unit should I use.
The new wiring I have installed in the extension is as follows:
1/ A ring main circuit with 3 double and 1 single socket
2/ A lighting circuit for 3 light fittings
3/ A separate circuit for an 500W outdoor floodlight
finally there is an armoured cable that supplies the shed, with radial main and light fitting.
As a first year electrical engineering student I would like to finish most of the work myself for experience and then have the Pro's back to inspect my work and connect the 10mm T&E to the main CU. So any advice on what CU to use, what RCD rating to go with & if I need a separate CU in the shed would be great.
