- Joined
- 11 Jan 2004
- Messages
- 47,108
- Reaction score
- 4,105
- Country
It's usually with reference to the space under the bath.
Indeed. As I said, I don't think the phrase appears anywhere in relation to the actual issue we are discussing.It's usually with reference to the space under the bath.
As I've implied, a lot really depends upon whether one is interested in common sense and/or regulations (and various interpretations thereof) and/or satisfying a BCO.If a normal triangular panel key was used for something like this (let's forget I said lockable?) reduce the problem? I have many of them so if I need to get in there then it's fine.
Not in a wall cupboard but in an airing cupboard - but that could then be more than the 600mm. whether it had a door or not - still steamy, though.However, as I said, a similar argument could be applied to Zone 1 (or even Zone 0), and I really don't think that it is intended that 'electrics in a cupboard' would be acceptable in such a Zone, do you?
Only with regard to under the bath where zone 1 actually becomes outside the zones if only accessible by a tool.As always, your guess is as good as mine as regards what was their 'intention'. I would personally say that a key left in a lock was not withing the spirit of 'only accessible by means of a tool'. However, does that phrase actually arise anywhere in relation to what we're talking about, anyway?
I think I must be misunderstanding you, since I would definitely struggle to think of how one could have an airing cupboard in Zone 1 or Zone 0! Could you perhaps clarify?Not in a wall cupboard but in an airing cupboard - but that could then be more than the 600mm. whether it had a door or not - still steamy, though.
No, he's not, but you were replying to my comment (which you quoted) ...Well, no but it could be right next to the bath end - just as near but just bigger. The OP's isn't going to be in zone 1, is it?
... to which you replied (quoting my comment above) with a comment about airing cupboards - hence my confusion!However, as I said, a similar argument could be applied to Zone 1 (or even Zone 0), and I really don't think that it is intended that 'electrics in a cupboard' would be acceptable in such a Zone, do you?
Ok, fair enough but you said:No, he's not, but you were replying to my comment (which you quoted) ...
which to me implies that similar rules may apply.However, as I said, a similar argument could be applied to Zone 1 (or even Zone 0), and I really don't think that it is intended that 'electrics in a cupboard' would be acceptable in such a Zone, do you?
Well, that's really what I was implying - that it if one is going to argue that electrical equipment which would not be acceptable within Zone 2 is OK within a 'locked' cupboard which is at least partially within Zone 2, then (given that the regs say nothing about cupboards in any Zone), one could (common sense aside) presumably equally argue that the same applied to Zone 1 or even Zone 0.Ok, fair enough but you said: ... which to me implies that similar rules may apply.
