consumer unit
22 Oct 2005
Yorkshire
I want to replace old consumer with new one split load 6+6 with rcd protection.I am considering ,HAGER,WYLEX,or CRABTREE.Which is better one.Thank you.
I only use wylex, so easy to use and the price is quite good as well,
Everything is already set up for you when you buy it,
Good luck
I like Crabtree kit, for no real specific reason I just find it a tad more robust to work with than Wylex.
Apert from choice of equipment are you perfectly happy you know what you are doing? What sort of board are you planning to replace with the 6 + 6?
Even though the only difference is the name on the outside? :wink:
Starbreaker system - once the requisite busbar is in place you just pull 'em out and pop 'em in. Ooh er missus :)
