Oh, I wouldn't say that - there is "always one" (or more)I am 100% convinced that there would not be an electrician in the land who would agree with you.
Otherwise, I totally agree with you.
Kind Regards, John
Indeed.One risk lies in trying to make policies or promote ideas based on data which comes from Fire Services who do not like (cannot?) to put "unknown" as cause of fire, and therefore put down "electrical" when it's actually unknown.
...and also that 'electrical' is often a scapegoat used to describe the cause of a fire when no other cause can be identified
The edison screw lampholder is less safe, but seems more widely used nowadays - is it because it is cheaper to make than the traditional bayonet lampholder?
Yes, the UK is not totally alone. I believe that some remants of, or previous parts of, 'the Empire' and a few other anglophile territories adopted the post-war UK practices.In Hong Kong, they also use 13amp fused British Type Plugs and sockets, often supplied off a Ring Final Circuit on a 32amp breaker...
It's actually getting worse ... looking around, it appears that 'electric cooking appliances', tumble dryers and electric heaters are, between them, responsible for a high proportion of 'electric fires' - and that in a high proportion of these cases, the fire is really nothing to do with the electricity - but, rather, the heat (often combined with misuse) intentionally generated by those appliances, and ...One risk lies in trying to make policies or promote ideas based on data which comes from Fire Services who do not like (cannot?) to put "unknown" as cause of fire, and therefore put down "electrical" when it's actually unknown.
Even the ESC, whose data I am generally not very impressed with, say that only 11% of 'electrical fires' are anything to do with the electrical installation or misuse thereof, the other 89% being due to appliances (and/or misue of appliances).Even the suspect data you've been banging on about shows that the vast majority of incidents are nothing to do with fixed wiring, ....
There are many systems today which only exist because of history. Live rails on railways and gas stoves I am sure would not be permitted. But if we take for example the gas stove in early days the electric stove was a length of coiled wire stretched around a porcelain former which was slow and dangerous when the element failed it would often make the pan live so compared with that gas was both faster and safer. However today with induction hobs gas is slower than electric and far more dangerous.Imagine if we had never had ring finals, and in 2013 you put forward the idea that we could have circuits wired in cable too small for the OPD, and that as long as it was in a ring, and as long as we told people to ensure that the loads were fairly well balanced, and as long as we told people not to have unfused branches of more than one socket, and as long as we introduced fused plugs and as long as we told people to not use the wrong fuse rating in them, it would all be perfectly safe, safer, in fact than 15/16A radials.
Which? once gave a microwave oven poor marks for safety.It's actually getting worse ... looking around, it appears that 'electric cooking appliances', tumble dryers and electric heaters are, between them, responsible for a high proportion of 'electric fires' - and that in a high proportion of these cases, the fire is really nothing to do with the electricity - but, rather, the heat (often combined with misuse) intentionally generated by those appliances,
It can often be a better design. I have some wall lights - glass quarter spheres quite high up on the wall - which would be a complete mare to relamp if they were bayonets, given the angle your hand would have to achieve, and the pressure you'd need to apply.Because it's the standard fitting in europe, and the UK market is flooded with cheap tat from china.
Yep, and the ESC (maybe aided and abetted by the Fire Service) would probably classify that as an 'electrical fire' if it extended beyond the potato.Which? once gave a microwave oven poor marks for safety. Reason? It allowed people to set longer times than any of the others, and if you left a potato in there on full power for a couple of hours it would catch fire.
Maybe, but if it comes with a timer which can make it run for long enough for that to happen, it really would be a dangerous appliance, well deserving of failing a Which? test.I would expect the transformer in the microwave to catch fire if run for that long..
Err no. The DB breaker can be single pole - it disconnects the line (live) and leaves only the neutral (near earth voltage) connected. That is no different to our system.I firmly believe the German Schuko is "misguided" as it is not polarised. This means that all the circuit breakers in the dis-board must be double-pole ...
