Continual restart attemps after HW use
4 Sep 2006
Cheshire
I've got a Worcester 24CDi which is working fine but for one issue. After using it from cold for HW for more than a minute or so, after I stop drawing HW it starts trying to fire up again. I can hear the fan spinning up and relay clicks and then it stops again. This start up and then stop process is happening every second or so and it does this in bursts of about a minute for the next 10 mins or so. The system is probably about 5 years old. Is this likely to be a faulty temp sensor? I intend to get someone out to it but was wondering if anyone has come across this before. Any pointers would be most appreciated.
It sounds more likely that the DHW flow switch is sticking on.
I have not encountered that problem especially on your particular model.
Tony
Cheers Tony. I'm going to get someone out to it and get it serviced at the same time. However, I'll have a look at the flow switch first with a multimeter if I can to see if its the culprit.
overheat protection. possibly cdi protects itself "by removing residue heat by turning on fan and pump", but yours sounds as though its going a bit too long.
