Contraction Joints In Concrete Slab
15 Jul 2008
We will be pouring our concrete slab over Celotex soon and wondering whether we need any contraction (or expansion) joints? The entire floor area is approximately 9m x 9m, with two load bearing walls marking of a corner (as pictured). Do we need any joints, or is a straight pour going to be fine for residential purposes.
The usual recommendation is for some form of movement joint to be created in a non-reinforced slab at a separation of approximately 30 times the slab thickness. So, for a 100mm thick slab, there should be some for of joint every 100m × 30 = 3000mm = every 3.0-3.6m and, in a 150mm slab, 150 × 30 = 4500mm = 4.5-5.4m. Naturally, there is some leeway with these calculations, and joints can be positioned to coincide with band courses or to be 'centred' within a slab for aesthetic reasons.
http://www.pavingexpert.com/concjnt1.htm
If those walls are load-bearing, should they be built directly off an un-reinforced slab on insulation board?
They are already in place on footings. The slab is being poured around them.
