    Dismiss Notice
Convert outdoor wall light to plug socket
Discussion in 'Electrics UK' started by pickles88, 28 May 2019.
  1. pickles88
    pickles88
    10 Apr 2018
    27
    Thanks Received:
    2
    Country:
    Hi all,
    I want to change an outside wall light to some festoon / string lighting. They both run on 240V but the festoon lights have a fixed plug on the end. Can I convert the outside wall light to an outdoor socket? Does it have to be RCD socket? I would have taken the plug off and hard wired it in but apparently it invalidates the warranty. Would this be a better option?
    Cheers
  2. EFLImpudence
    EFLImpudence
    7 Jul 2010
    31,705
    Thanks Received:
    3,441
    Retired to:
    Country:
    Portugal
    Is it just a normal plug or a wall-wart power supply?
  3. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    Whereabouts in the UK do you live?
    If the circuit isn't RCD protected, yes.
    Untrue.
  4. pickles88
    pickles88
    10 Apr 2018
    27
    Thanks Received:
    2
    Country:
    It’s a normal plug. I was thinking of just getting an outdoor single plug socket from screwfix and doing it, but given it’s maybe 2.4 metres up it might be a faff.
    If I opt to take the plug off and hard wire it in an outdoor junction box, should I fix to the wall and then silicone over the top of the box to stop water ingress?
    I am in East London and thankfully about two minutes from Screwfix!
  5. chivers67
    chivers67
    18 Nov 2008
    1,101
    Thanks Received:
    118
    Surrey
    Country:
    You can get IP rated boxes, Wiska do some and stuffing glands to
  6. winston1
    winston1
    11 Jan 2010
    5,668
    Thanks Received:
    415
    London
    Country:
    It is also bad practice (though surprisingly allowed) to put a 13 amp socket on the lighting circuit.
  7. Risteard
    Risteard
    18 Jun 2010
    1,981
    Thanks Received:
    134
    Derry, Ireland
    Country:
    Ireland
    Hardly that surprising...
  8. aptsys
    aptsys
    16 Sep 2007
    1,705
    Thanks Received:
    126
    Cambridgeshire
    Country:
    Isn't every electrical enclosure IP rated?
  9. Sponsored Links
  10. bernardgreen
    bernardgreen
    3 Nov 2006
    22,722
    Thanks Received:
    2,140
    Bedfordshire
    Country:
    It is Winston's opinion that it is bad practise, an opinion based on the probability that someone could plug a high power appliance into the said 13 amp socket and thus trip the 6 amp MCB
    It maybe that Winston is a ( founder ) member of SEPSAFM
    Society for the Ensured Protection of Six Amp Fuses and MCBs
  11. pickles88
    pickles88
    10 Apr 2018
    27
    Thanks Received:
    2
    Country:
    I read this on another thread I found using the search function. It makes complete sense really. Whilst in this case it would be abit ridiculous for somebody to plug in a tumble dryer using an outside socket that is 2.5m high up the wall, I can easily imagine power tools or a lawnmower being plugged in...
    The only other option is to strip the plug and connect in the junction box.
    I'll look at these also, thanks.
  12. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    But that is a bizarre opinion which the OP can ignore completely.
  13. chivers67
    chivers67
    18 Nov 2008
    1,101
    Thanks Received:
    118
    Surrey
    Country:
    Yes :rolleyes:
  14. EFLImpudence
    EFLImpudence
    7 Jul 2010
    31,705
    Thanks Received:
    3,441
    Retired to:
    Country:
    Portugal
    Like a bucket; IP00 at the top and IP68 sides and bottom.
    • Like Like x 2
  15. JohnW2
    JohnW2
    28 Jan 2011
    42,924
    Thanks Received:
    2,730
    Buckinghamshire
    Country:
    True, but the worst that would happen if someone did plug in high-powered power tools (more than about 1,300W) or a lawnmower is that the 5/6A fuse/breaker protecting the lighting circuit might blow/trip - that's what they're there for.
    Kind Regards, John
  16. winston1
    winston1
    11 Jan 2010
    5,668
    Thanks Received:
    415
    London
    Country:
    It is not a bizarre opinion. Even the OP agrees it is common sense.
Loading...
Share This Page
