Converting Conservatory to Living Space
1 Jan 2007
We currently have a part brick convervatory which we never use as its too cold in the winter and too cold in summer. We now want to convert the conservatory into a living room by building a proper flat roof, I was hoping there would be a builder out there able to tell me if this is possible. I have been told it depends on how deep the foundations are, I have no clue as the conversatory was already there when we purchased the house. If it was possible to build a roof does anyone know roughly how much this would cost?
Thanks for your help.
Susie
___________________________
lynda, moderator
please see forum rule 9
if you intend upgrading under a buildings notice, i.e. via building control then you will have to adhere to regulations.
foundations will have to be exposed and checked. you will need to achieve certain 'u' values in the floor, walls and roof. this may mean loosing some of the window area too.
i would imagine for the simplest of conversions, expect to pay upwards of £3500.
An insulated, lightweight roof is feasible. A typical conservatory foundation should be sufficient (although may not be to bregs), but the main issues are how to support and attach it to the existing framework. There are numerous other issues to consider to - mainly centering around the need for building regs approval, but also just how comfortable the room will be if you just try and 'adapt' it, rather that do it properly
If we consider £3.5k for the converson and then application and design fees (say another £1k) then I would ask how many years could you heat the conservatory as it is for £4.5k? Plus the disturbance and other factors if you got the work done
Then you will have the viability of doing the conversion.
