I currently have a open vent conventional boiler which will be replaced with a combi, I'm planning on removing the tanks and cylinder and modify the pipework ready for the plumber to fit the new boiler
Cylinder is in the bedroom cupboard
Boiler is in the kitchen
Having read a few posts, if I have understood correctly are the following procedures correct?
I want to ensure the pipework is most efficient for the flow of the taps and heating and do not want any unnecessary dead pipework where water has to travel unnecessarily.
- Remove f+e tank and remove all pipework in loft down to cylinder
- Remove cold water feed tank and remove all pipework in loft down to cylinder
- Remove and cap CH flow and return from cylinder
- Remove and cap mains water feed from loft down to cylinder, do the same with hot water and do the following instead of routing new pipework:
Rather than extending the hot water pipe and main cold pipe from the cylinder down to the kitchen, is the following acceptable?
- Tap into the kitchen taps to obtain cold water main and hot water
I would appreciate your comments
