Converting window opening to door opening
21 Jun 2007
Not sure if this is the right section but here goes:
Our dining room has a large window looking out onto the rear garden. We want to remove this window and replace it with upvc french doors.
The door wont be as wide as the window, but I want to fit small windows of the same height as existing either side of the door to plug the gap.
Therefore I shouldnt need any brickwork?
I take it its just a case of removing the window, cutting out the brickwork under the window opening to fit the door, but what next?
Obviously this would cut through a cavity wall, so how would this be re-sealed before the door is installed?
Yes you’ve got it! But the windows must comply with current regs. & have either a FENSA or BC certificate of compliance & BC may be want to inspect to make sure your doing it properly; ring your local Council to find out.
Use cavity closers on the cavity, a DP membrane on the sill (if neccessary) , plasterboard over the reveals & finish plaster the reveals after installation. Not going to go into detail here, use the search engine & read the archive posts as its been covered many times before, quiet recently by me but also by many others!
