Converting a garage, where do I get a replacement window+ do
4 Oct 2005
Oxfordshire
I am converting my garage to a dining area, I want to replace the garage door with a patio style door and windows. That is, door in the middle and window either side. It must be georgian in style to keep with rest of house. Is there anywhere in Uk where I can get an off the shelf replacement 2130mm wide(a nominal garage door opening) patio door/windows?
Tex, the 2130 is a width not height, I could make up a distance of a100mm using standard upvc distance pieces, anything more starts to look silly.
Thanks for looking!
Thanks for looking!
:oops: I really should pay more attention. I thought that page included a 2100 x 2100. It is a pretty standard size. It's also well worth checking out some of your local joiners. Their workmanship is generally far higher than the "off the shelf" product and you may be surprised at how competitive their prices are.
Tex, your reply was posted at 03:35, you need to get to bed earlier or change your job! I am hoping to do the work myself, can't afford tradesmans rates in Oxford, do you know of any that could quote? I have access to a white van, I don't mind distance for the right price.
