Cooker Hood Power Lead...
23 Jan 2012
Gwent
Hi
I'm going to be fitting a new hood above the cooker.
The problem I got is the power cable is too short.
It's an IEC lead (like a kettle cable) that unplugs.
I was wondering if I could just buy a longer IEC lead and use that?
I was thinking about getting a 5m lead and cutting it down to suit?
Joe
To go where?
Extension lead ?
Yes, of course - if available.
Extension lead on original ?
You could always install it properly.
Hi
The power cable that's on there at the moment is really short.
I'm going to use a new longer IEC lead.
Then I can run the cable neatly rather than do a bodge with what's on there at the moment.
The cable will run to the FCU thats on the wall ready
And it would be installed properly :)
Unlike what I replaced. Which was an FCU placed above the outlet of the old hood.
They wired it from a socket using 1.5mm T/E cable and used a 13 amp fuse.
I just wanted to make sure I can use any other IEC lead.
TI'm going to use a new longer IEC lead.
Ok. I take it you are going to cut off the plug and connect to the FCU?
That's fine.
It is. I was imagining the cable hanging across the cupboards to a socket.
Nothing wrong with that.
I'm confused again. Where is the FCU you are going to use?
Yes, if the rating is correct - it will be for a hood.
You may need 3A fuse if cable rated less than 13A.
Yes of course.
And I'll cut the cable down to the required length.
I didn't think it's very save to have hot air venting directly on to fused spur.
And I was always told never spur off from a socket using 1.5mm cable.
Heres something I quickly made ;)
View media item 48848(cable will of course run behind the cupboards)
It won't be that hot up there.
Yes, you are correct. Sorry to mislead you.
Although electrically satisfactory it is against the rules for a ring final circuit.
Yes, that's good.
Thanks for the help
Although I've done a fair bit of electrics and worked for an electrician in the past. I like to made sure what I'm thinking is correct before I do it.
