We are replacing a standalone cooker with an unknown rating, the short cable to the wall is 6mm.
The circuit is fused at 32A which would suggest a max rating of between 7000 and 7680 Watts depending on whether you use 220 and 240V in your calc,
All the ceramic hob cookers are way above this at 10kW or higher, so that is obviously no go, as this is a temporary new cooker before we move house so don't want walls chasing out for new fat cables (fuse box is about as far away from the kitchen as you could imagine, kitchen is fully tiled.
So I assume this limits us to either a dual-fuel gas hob/electric oven (we have a gas connection behind the cooker), or perhaps a old style solid hot plate which is no more than 7kW (which I can't seem to find anywhere, all appear 9kW or higher)?
Currently all the sites I'm reviewing list the oven power as a consumption figure kWh rather than just rating W/kW, is that a direct conversion is a oven which is rated a 1kWh equiv to a rating of 1kW? I presume that with a gas hob, the oven is only going to be a minor current draw and nothing above 3000ish Watts - am I correct in my assumptions?
(edited for typo)
(edited for typo)
