Help! I have a problem in my house that I know I am not going to be able to fix myself, but would like some advice before deciding how to tackle it. I am not an expert, but will try to make the problem as clear as I can!
We noticed that whenever we used our main oven and the lower oven grill together the main 100A RCD in our consumer unit was triggered. It wasn't always immediate, but would happen at some point or other (with mutinous results from children with unsaved games or work!). The oven appears to be rated at 4.6kW according to a sticker on it. We also have a power shower in our ensuite. This was put in 2 years ago, using existing wiring from an older electric shower (power rating not known), but I would think a power shower would have a lower rating than an instantaneous one which has to heat the water (am I right?), as it is merely pumping water which is already hot.
I always thought that cookers were on their own separate circuit breaker, and sure enough when I checked the NICEIC inspection certificate the cooker is noted as having its own circuit with a 40A circuit breaker. However, on checking the consumer unit, 'Cooker' has been crossed out, and 'Shower' written below the 40A circuit breaker. Some basic testing reveals that the oven now runs on a ring main with a 32A breaker, which also supplies 12 double/1 single sockets in various rooms. Only the shower is on the 40A circuit. Obviously the previous occupants were not averse to some corner cutting to save money! We do not use the oven grill at all now, so it isn't a huge problem, but we are selling and need to fix the problem before we move (unlike the previous occupants we will not leave our buyers with a heap of problems!). How is this resolved? Will putting the shower onto a new separate 30A CB, and the cooker back onto the 40A CB work? Why does the 100A RCD trip before the 32A CB? Sorry for waffling, and thanks to anyone who stays awake long enough to provide any advice they can!
Andrew
Andrew
