Cooker Socket/Fcu
24 Dec 2003
Hi Guys/Gals, I’m about to start a full rewire on a friends house,
Part of the kitchen wiring requires a socket or fcu for the cooker,
The cooker is gas and requires 230v for the timer & ignition,
To the left of the cooker is a sink, So I can’t put a socket there,
To the right of the cooker is a doorway, So no socket there either,
The socket or FCU cannot go directly above the cooker,
And the friend does not want to resite the cooker,
What the F**k am I suppose to do, run away, :eek:
Would really appreciate your logical responses, :cool:
Well without seeing it, it sounds like behind the cooker is the only place available? Since it's not something you'll be unplugging unless you're moving the cooker anyway, I don't see this would be a problem.
Cheers,
Howard
you could put a masterseal switch on the sink side feeding a socket behind the cooker
fit the socket under the sink in the cupboard, remove the plug from the cooker drill a small hole feed cable into cupboard reconnect plug and plug in
