- Joined
- 31 May 2016
- Messages
- 27,388
- Reaction score
- 6,595
- Country
Do you even know how to calculate U?
Does insulation make your house hotter?You clearly have some learning to do
But "other things like shading and proper ventilation have a much, much bigger effect and can reduce the internal temperature substantially", he said.You clearly have some learning to do
Only early (cavity) buildings that are poorly ventilated. Luckily B'regs and conscientious builders focus on both.![]()
He clearly isn’t otherwise he wouldn’t be spending all his time on here taking about hot airI honestly can’t believe someone can be a successful builder without a basic understanding of what U-values are and why heat loss/gain is based on the temperature difference.
"Insulating homes has very little, if any, impact on the risk of overheating," said Professor Kevin Lomas from Loughborough University, who led the largest national study so far into overheating in homes.
Insulation can even help keep your home cool, because most types - certainly external wall and likely also cavity wall - will stop your home from getting as hot in the first place.
Other energy efficiency measures work both ways too: insulating pipes saves energy in winter by preventing heat from leaking - and so helping keep your home cool in summer.
The exception when it comes to insulation is if you have it on the inside of your wall, which can create a "small additional risk" of overheating by one degree Celsius or so, but only if your home isn't well ventilated anyway, explained Prof Lomas
Insulation changes the speed of transfer. The slower the transfer the less heating/cooling is needed to maintain a given temperature based on the temperature difference.That seems pretty clear. And it chimes with what Jurassicspark said about his external insulation.
I've remembered now that about a decade ago there was a local news report on overheating in some new build flats, but they put that down to big windows with unsuitable glass.
That’s why new builds have a typical heat loss off 4-6kwIt also means the greater the impact of any heating / cooling source desired or otherwise.
Insulation can even help keep your home cool, because most types - certainly external wall and likely also cavity wall - will stop your home from getting as hot in the first place.That seems pretty clear. And it chimes with what Jurassicspark said about his external insulation.
No. Architects specify a number. It's up to us how best to implement the products to achieve it.Do you just rely on building control to tell you what the U value is?
There is no slow transfer of heat leaking through the PIR or the air gap.Insulation can even help keep your home cool, because most types - certainly external wall and likely also cavity wall - will stop your home from getting as hot in the first place.
Likely doing a lot of heavy lifting there.
I can totally see how external insulation will help keep cool but not cavity - once that sun gets on the brick every day and builds up and maintains the heat then that cavity insulation canni change the laws of physics captain
It's unequivocal.That seems pretty clear
Eh? It's covered in render - usually?External wall insulation is often light coloured as well, which will reflect more of the sunlight than darker masonry.
You mean if there was an air gap? Like in some PIR partial fill cavity wall scenarios?It seems intuitive that the further away from the inside of the house the insulation is, the better it will be and stopping heat from entering
Of course there is. It’s expressed in W/m2. It’s what the friggin U value is.There is no slow transfer of heat leaking through the PIR or the air gap.
