Hi
Here's a picture of my cylinder in airing cupboard. From previous posts you'll know I do not get any hot water, but radiators work fine. Its a Potterton system from the 70s, there are no options to turn on hot water/rads seperately, you only get hot water when the radiators are on!!
The picture shows the two pipes (A) that I believe should feed hot water to the indirect coil, and (B) takes it back to the boiler?
As the cylinder remains freezing cold even with the heating on overnight, I've been told the cylinder needs replacing. My question is, should the (A) pipe not even get warm or hot? because at the moment its stone cold???
The feeder tank is full but looks as though the waters been static in there for sometime?
any suggestions of what to check next?
//media.diynot.com/209000_208117_66208_76806473_thumb.jpg[img][/img]
