Hi all, just looking for a bit of advice on a spot of DIY.
I've had to replace a section of concrete floor - about 2ft by 1ft. Underneath the length, I've unearthed a copper radiator pipe. The pipe isn't lagged in anyway, in fact, it's just surrounded by grit and hardcore.
I'm wanting to correct the patch of floor, but don't want to do anything that would cause problems with the piping.
The options I'm weighing are:
1) Fill the hold with sand, using a thin layer of cement on the top.
2) Cover the pipes with horsehair type insulation, then do as above
3) Try and put a steel channel over the pipe, then as 1.
I thought about encasing in plastic, but at the moment, it's only one pipe exposed, and it's not free all the way round - would need further clearing to do this.
Any advice greatly appreciated (unless you're suggesting digging up the whole lot and resiting!).
