I have installed a towel radiator and the copper CH supply pipes run inside a brick wall. I have chopped out a reasonable amount for the pipes to run but now the wall needs to be made good. I know I can't use cement or plaster round the pipes and it will be tricky wrapping anything round the pipes as access is limited and the rad is in use. I was wondering if there is a problem using expanding foam from an aerosol to fill the space. I could blank off at the wall surface and inject behind. Is anyone aware of an incompatibility problem between this foam and copper?
