Core Drills 70mm deep into 100mm block
11 Oct 2013
Hi all.
I have seen many 70mm deep SDS core drills for sale online.
How do these work when it seems that most blocks / bricks are 100mm thick.
Thanks for any help given.
SC
Use a long SDS dril the same diameter as the pilot of the core drill, then drill right through the wall, use the core drill to say a depth of 60mm then drill from the other side of the wall , this will avoid unsightly breakouts.
Wotan
Hi all.
SC
Most of the cores you drill disintergrate as you go , so pulling out every few minutes releases the debri.
Any that don't break up you just tap with hammer and bolster and remove.
