Corner bead on existing dry wall
23 Jul 2016
Hello guys
Planning to do my corner bead on the walls at the moment.
The guy who converted this flat did a very bad job with the corners. Instead of using corner bead, he used 2 separate strips, which I've never seen before.
Anyway, Am I correct in saying that in order to do this, I will need to strip off the corner, stripe off the 2x metal stripes. All the way to the plaster board?
For the surrounding wall around the corner, what level should I stripe it back to?
Also, looking for the corner bead this guy used in the video?
Where do I get these, looked through screwfix and wicks, can't seem to find it.
Much thanks. :)
Dont go near Wickes or any other shed, use a local builders supplier.
The strips you refer to sound like metal strip corner tape.
How many taped corners do you have?
Why not post pics of what you have?
