Attempting to self build an extension.
Is this the correct blockwork layout for the internal wall or is there a better way to lay it out?
The 75mm will be celcon coursing block, the 225mm are celcon internally and 7n concretes external. Can I use concrete commons externally?
Will I require padstones for an IG type 3m span cavity lintel?
How many courses less will the external wall generally be or are they the same height? (pitched roof)
When I form a cavity tray over the lintel is it OK to use DPM or is there a specific material to use?
Thanks....
Thanks....
